M
Michael A. Boyle
Guest
" Hello Joe Reeves and others,
I have acquired an H-E motor that had me scratching my head until I came across y'alls discussions. Very good information - I thank you! The info helps explain the oddities that I have encountered. Everything has checked out OK so far. I still have to replace the red Auxilary Throttle handle and then put fuel in it to attempt a start. Joe: is the handle readily available? If so, how much?
Sidebar: How does the throttle cable engage the throttle handle? In mine, there appears to be some disconnect (no cable motion when moving lever). There is no grinding sound or other observed odd condition, just no motion at the engine throttle lever.
This boat was recently purchased as a "unique fixer-upper opportunity". "Ran great when parked!" :^D
Much thanks! "
Much thanks! "
