I had an earlier post about ignition on this motor and all is well now and it runs awesome but I did have to put the head back on this motor and now one of the cylinder head bolts leaks slightly. I replaced the head gasket and surfaced the head so it was smooth like described in other posts. I did unfortunately misunderstand the torque settings and over-torqued the head bolt. I have since torqued it to 7 inch lbs but it still leaks.
Would this have damaged the head gasket and be the cause of the leak ? If so I will order a new gasket and try again. I tried putting thread sealer on the bolt but that didn't make any difference. It's only weeps slightly but I'd like to fix it so I don't have to think about it.
