Hello,
New to the forum and pretty new to engine troubles. Recently rebuilt a 1967 Starcraft boat and put on it a 1969 Johnson 33 that came with it. Purchased a new ignition switch and moved wires from old to new. Ignition type I got is under this link; http://www.amazon.com/gp/product/B004XADLC2?psc=1&redirect=true&ref_=od_aui_detailpages00 ...
However, after starting the motor and everything running well, I ran into trouble shutting her down. Putting the ignition key to off position does nothing. I was told that it might be the switch since it says 'Merc' in the title on Amazon, others said its my cut off wire... I can't locate it on this motor at all, I see no black/yellow wire... looking at the wiring, I found the cutoff switch and the wire pointed with the red arrow I'm thinking is the cutoff wire?? that wire is quite crunchy, I'm wondering if someone can help me. I can replace that wire if that is it.
Thank you in advance.
