John Fisher
I have a 1969 Evinrude 85 HP with Selectric shift. The motor works great and has plenty of power in forward gear. However, when I select reverse, It works until I get a little above idle. After that it sounds like the gears are not making contact fully and grinds or rattles rather than grind. There is no reverse power at all above idle speed. I tested it out of the water and it goes into reverse and the prop spins fine even above idle, but under load it will not work properly. I recently changed the lower unit oil thinking that was the problem. When I changed the oil there seemed to be water in it. I still have this problem though. Any help would be appreciated and tips on a starting point. Thanks.
J
J
