1969 evinrude 6 Hp
larry
" Recently aquired a 1969 evin
" Recently aquired a 1969 evinrude 6 hp and it exhibits classical "bad fuel pump syndrome"..
My question is whether or not a later model fuel pump kit or replacement pump would fit on this engine.. From all appearances, the size looks the same though the mounting position on the later models is unknown to me... Help... "
" You can run the engine with
" You can run the engine with the primer bulb as the pump. My guess is that the motor has the " classic" cracked and shorted ignition coils. Check them out by removing them and closely examining them and best take them to a dealer to be tested on a MERCATRONIC tester , Nothing else tests them as well as that unit. "
