dirtyfrank
" Have a 1969 Evinrude 55hp.
" Have a 1969 Evinrude 55hp. Motor seems to run fine out of water, can push to WOT with no problem. When motor is in water, runs fine at idle and with some throttle but at WOT, seems to sputter and clunk along if I drop throttle again to idle runs fine. Fly wheel nut keeps coming loose (do I need to use lock tight), notch on rotor keeps breaking off and I've torn up one fly wheel key. On third rotor now. Was thinking it was gear related, noticed gear case could use some more oil and thought maybe there wasn't enough to keep clutch dog in gear, added more. Going to take it out again and if it still clunks along ,next step was to check the clutch dog. Any other ideas, I'm tired of buying new rotors. "
