Doc Davies
Hello,
I have a couple of simple question about lubricating my 1969 25 hp Evinrude outboard. I need to lubricate the lower unit and am trying to figure out where to add the grease/oil. i am used to more modern engines with a zerk nozzle that you can just squirt grease into with a grease gun. On this outboard, however, it appears as if there is a drain plug at the bottom near the prop that you simply open with a phillips to drain some oil. On the same side of the engine, about 1/2 way up the shaft is a rectangular plate that can be removed, which is where it looks like you would add the oil. My question is where you add oil or grease to lubricate the lower unit? If so what type of oil should I use? Also I only found 2 zerks for the throttle arm. How would I lubricate the tilt and steering, etc.? I cant seem to find any other zerks.
Thanks for your help.
Doc
Doc
