1969 Evinrude 18 hp electric starter
gtodd
"Just accquired a 69 Fastwin f
"Just accquired a 69 Fastwin from an old fishing buddy and would like to add an electric starter. If anybody has any ideas at all, as to where I might find a used one, or kit, #172180 or newer #172401, i would be greatly appreciative."
"i will look,in my acc book,tu
"i will look,in my acc book,tues,morn...the compl kits r real high priced..if u piece it together,its cheaper....sierra,has the starter,and solenoid, shop.evinrude.com will show the starter bracket u will need..may have to dig around a while,..like one for a 25...u do,have a ,..toothed, flywheel?"
"bracket--0308482 BRACKET, Po
"bracket--0308482 BRACKET, Port. ELECTRIC START MODELS 1 $182.58 USD Available
bushing--0304789 SHOCK ABSORBER. ELECTRIC START MODELS 1 $2.20 USD Available
starter--0385401 STARTER MOT0R ASSY. Not Shown 1 $251.75 USD Limited
solenoid--0383622 SOLENOID ASSY 1 $36.99 USD Available
0311217 SLEEVE, Solenoid 1 $4.64 USD Available
0121562 BRACKET, Solenoid mount 1 $27.41 USD Available
0311218 CLAMP, Solenoid 1 $9.35 USD Available
then,all u need r batt cables,and wiring,switch..this eng,better be a goodun,!"
"thanks jwbmarine. the numbers
"thanks jwbmarine. the numbers will be a big help. this eng came from a trusted friend though i've yet to run it in the tank. if it works out, i'd like to have the elec start. i'm looking to find a parts motor to cut the costs and get what parts i need. other than sierra, what sources would you recommend for parts?"
