1969 Chrysler 85HP water pump test
J
Jeremy M
Guest
"I need to know if this motors
"I need to know if this motors water pump is working ('69 85hp). It wasn't ran for six years. I got it running, but couldn't tell where the water would even come out of the engine. If you could help, please comment."
"Most model will have a "t
"Most model will have a "tell-tale" or "pee-stream" that exits from the rear of the motor in the lower engine pan.
If you pull your hood and go to the back of the engine, you are looking for a hose that comes from somewhere on the head and goes down to the pan.
Needless to say though, if you had it running and didn't observe any water coming out, the impeller is probably shot.
However, this is an old Chrysler of which I am not familiar and it may not have a tell-tale - so do look for the hose...."
