1969 85ESL69E Where is the Pee Hole ?
Burmman
OK I just got the boat and it has been told to me that it has just had the water pump impeller and all changed and is new. I took the boat out and let it still and run at the dock for about 10 min and also ran it on the lake for about 20 min. I didn't see a Pee Hole or really any stream of water coming out of the engine. Now I understand that the 2 exhaust holes have alittle bit of water or mist coming out but , Where does the water come out of ? I just want to make sure everything is working right. I ran it for about 30 min and it never overheated and ran great but just want to know. Please help
There is no " pee hole " on that motor from the factory.-----------Not needed if you install a new impeller every 4 / 5 years !!!--------------Most of the cooling water goes out the bottom with the exhaust just like any other motor.
Thats what I thought also but just wanted to check and make sure before I messed up a perfectly good engine. Thanks for your fast reply.
