Jerry Moss
Just started after setting several years. Put in new thermostat...water pump assembly...and lower end lube. Old lube was fine with no evidence of water so I assumed seals were good. When started seemed to water good but a lot of water coming front front of motor just above the lower unit.. and seemed to water less I think when thermo opened. Is this normal??? Also a lot of watered grease was coming from the exhaust hole instead of water. ..Any input...maybe seals are bad? have some pics but site won't take them.
