Dear Joe and everyone,
Recently I had a post about no spark on this motor with a single auto coil. Thanks to Joe, I attached the red wire of the powerpack to the rectifier terminal to get 12V going into the powerpack. It immediately gave strong spark in all cylinders. I attached the fuel and got it to start up and run with the cold start throttle lever up. Unfortunately, I shut this sayin lever and the motor died out. I couldn't get it to start again. I took out the 3 carburators and cleaned them up real good with aircompressor blowing thru everything. I reinstalled and reset the idle needles to 1 1/2 turn open. I can not fire it up again. It drained a couple batteries I have and can't get it to start. Also, the gas seems to be flooded back out of the carbs where the choke flies are.
Can you please help me point out what possible be the issue?
I took out the carbs and recleaned again today. No better result. I rechecked the spark; all are there still. I used QL77JC4 plugs setting at .030 inches gap. Did almost everything I could from learning on this site and from Joe. It has been a hot week and I've been burnt out from this motor.
Please help me!
Thank you much in advance.
Please help me!
