I have about 10 of these around my shop. They are a great motor, compact and with plenty of features beneficial to the fisherman. The smoke problems come from too much oil in the fuel mix which when trolling can choke out the motor if the breeze is not carrying it away from the transom area. I have solved that by using Amsoil at 64:1 mix with non ethanol fuel and drilling about 5 to 8 1/4 inch holes in the lower cowling somewhere handy like below the carb. This offers more air intake than the engineers offered. Secondly, these crank seals are very suseptable to ethanol damage. I have had to change many. Its most often the upper seal which is quite easy to change using my special drill and a couple small self tapping screws. The lower seal, however, requires dismantling the entire motor cowling, then, of course, removing the lower unit and center leg section. You will know if a crank seal is bad when you can't get it to troll properly for any amount of time without the "cough", or sneeze. Seals on these were a rubber composition and I have several that I replaced on top of my work bench to show customers what ethanol does.
I could write a book in these 9 1/2's. Have great love for them. Not as strong as the 10 hp or newer 9.9's, but pretty close. How about that trim system, shallow water drive, gear shift right up front, tiller handle versatility, very low profile, very quiet running and so easy to carry.....perfectly balanced. Really, to me, it is brilliant engineering. Truly designed for the small boat hunter and fisherman.
