Paid 20$ for the motor
Compression test 2x66 lb
Carb cleaned with forced air and carb cleaner
Fuel lines new all the way to the gas tank with new primer bulb
Cleaned the little fuel pump I believe is vacuum?
Fuel is non ethanol (90) mixed @50-1 or as close as possible
So I can get this motor to run, but for the life of me I can not get the motor to stay running.
It seems to want to run (rev up) when I close the choke. I'll make a 1/4 turn on the low speed needle, open choke wait a few seconds to see if it will idle. It chokes spirits sputters and dies. Over and over again.
I've started with the low speed needle from 1/4 turn out from seat and gone all the way to 3 full turns out. Do I keep turning? Is it still not getting enough fuel? Spark, compression?
I'll stop there. What is my next step guys!? Please help I want to get this Jon boat in the water!
Ohh and it does smoke like a bandit. But I've always been told they should be "Skeeter killers"
