1968 Johnson 6hp Compression Test
tidewater
Hi,
I have a 1968 6hp Johnson motor, doesn't want to start. Tested the compression and got 85psi on the top cylinder and 80 on the bottom. I'm completely new to outboard motors. Do I have a compression issue? What is the standard psi range I should expect to see?
Any help is much appreciated!
Those readings are satisfactory and well within 10% of each other
over 60 should run
over 80 should run well
over 100 very good
over 120 ... your gauge is wrong!
Thanks vics and kimcrwbr1, I really appreciate the help. I'll let you know what I get with the spark test, probably won't get to it until later in the week.
