"I have been restoring a 1968
"I have been restoring a 1968 Alumacraft Queen Merrie which has a 68 Johnson 100 model V4TL-14B. I have completed the boat and now am going through the motor.
Maybe I am taking on a project that will cost more than it is worth in this motor?? The motor has good compression shows very little corrosion or wear of the external pieces. I am planning on going through the lower end,rebuilding or replacing the water pump, rebuilding the carbs and doing a good tune up.
My main question is about the power pack which is OMC part number 0398362 and is available at a cost of $483. There are several after market products with sketchy availability for about 1/2 the cost. In looking at CDI PN-113-8362 it lists a bunch of OMC power pack numbers that it replaces including part number 385034 which Marine engine carries for $100 which works way better for my budget given that I am doing this project while I am looking for work. Yes, I am feeling the impact of the economy...Is this part(OMC 385034) also compatible with my motor?? If not, what is the best product to use as a replacement?Is there any concerns with after market power packs?Or should I just pay the big bucks for the OMC part???
Any thoughts or advice for me as I get going on this project would be greatly appreciated.
Thanks,
Bob"
Thanks,
Bob"
