"I just removed lower because
"I just removed lower because of water in the lube. I have a manual but I'm not totally sure how to rectify the problem. The impeller wont't turn. Also, 1 bolt that I assume holds the gearshaft bearing broke. The plunger on the solenoid is broke at the very bottom end. Is this unit repairable/cost effective? If so does anyone know if I can just order a seal and bearing kit and solenoid. There aren't any shavings or signs of metal in the lube just water."
