1968 Evinrude 100hp starflite
The 67 model was easy to retrofit to the 1966 style distributor.----But answer this.----Is there a cam ground onto your 1968 crankshaft to operate breaker points ?
Not that I have seen. I inherited this motor and the trigger is burnt up. Didn't know if it even could be converted to points.
That's why I gave a wise-guy answer. You would have to replace the crankshaft to get a breaker cam. Then a breaker plate and two sets of $$$$points and a coil and condenser and-----
I trust that you have established that the trigger is bad? I've never seen a bad one, but I haven't seen them all.
