Replacing water pump parts. Bought the kit. Hoped the bearing housing assembly part #0382292 would be included. It wasn't and the parts inquiry says no longer available. This housing holds the shaft seal to prevent water into oil and the brass sleeve bearing that aligns the drive shaft. The housing itself is ok. I am replacing the shaft seal, but would like to replace the housing as the brass sleeve in the housing shows some wear which will cause premature seal failure. Any suggestions?
