"Here is a summary that will h
"Here is a summary that will hopefully fill you in on everything I have done so far.
I have replaced the plugs, wires, points, condenser, and coil.
The champion plugs are gaped to .030
The points are gaped to .020.
The carb has been rebuilt. I disassembled it completely including jets, tubes, seats, needles etc and soaked in carb cleaner. After removing from the carb cleaner, I rinsed with gasoline. Then I blew out every orifice with compressed air.
I checked the compression and get about 95 psi in one cylinder and 98 psi in the other.
I checked the spark and it is hot blue and jumps a 3/8" gap no problem.
I worked on the motor this afternoon to double check everything and made an interesting discovery. When the throttle is turned to full so that the stop on the armature plate hits the stop on the shift inter lock and the throttle cam is at the max, the throttle valve goes beyond horizontal in the carb throat and continues until it is about 1/3 closed.
Is this normal or should the the throttle valve be stopping in a horizontal position? It seems to me that this could certainly decrease performance but I can not see how it could be adjusted.
Thanks for all your suggestions so far."
