papasteve54
I have restored my father -in laws 1968 tri hull boat with everything new except the engine. I replaced the ignition witch with a new marine grade ignition switch because the old key was lost. After eveything was done the engine started easy and ran great. I had a boat detailer detail the boat inside and out. The next day I went to start the engine before putting the boat in the water. Ignition witch went bad, don't know why. Replaced the ignition switch and now the starter turns over the motor, but it won't start now. Could the starter switch have caused something down line to go bad? Like the ballast resistor, the condenser, or the coil? I disconnected a park plug wire, and even disconnected the coil wire while turning engine over and saw no spark from either one.
