1967 Mur-Tex with 120hp '66 MC-1, '65 2.5l 4cyl. Motor is 12v neg ground. Installed Pertronix Ignitor and Flamethrower coil #40511.
We have 7.9 hours on the motor. Went to the river last weekend and ran for about an hour. Motor died and refused to start after all the initial checks for bad connections and such. Got a tow back to the ramp.
Boat set for three days. Set it on the muffs and it started right up. Ran for about 45 - 60 seconds then stopped. Waited a couple of minutes with the ignition off. Motor starts right up but only runs for about 15 seconds then quits. After a couple of tries to get it started I covered it up.
This morning I got her on the muffs and got my multi meter ready. Starts right up and I checked the voltage to the (+) side of the coil. Getting steady 12 volts. Runs for about a minute then quits.
I disconneted all the wires and checked the coil. There is less than 1ohm resistance across the posts (primary side?) and there is 8.5k ohms from negative post to center post (secondary side?). According to my reseach on the web I should see 10 - 11k ohms testing the secondary side but I have no idea other than what I researched.
From my experience the Ignitor module either works or it doesnt. So I assume it is working since the motor will start. As for the coil I have my doubts.
Two things have changed. The transistor voltage regulator fried. Determined, with help from this site, that the alternator has VR built in. Rewired to remove old TVR and ran on the muffs and in the river for a total of 1.5 hours. The other issue was an incident where we hit a chuck hole in the freeway pulling her back from the lake a couple of weeks ago. Didn't blow a tire or knock her off the trailer. The hole in the road was large enough that everything in the truck and boat was relocated. Kinda bone jarring but found no external damage. Could this bone jarring hit have damaged the coil?
Anyway, I am stumped on what to check next. I guess I could beg/borrow or buy another coil and test that first. Any other suggestions on what to test before throwing bucks at her would be appreciated.
I have checked my fuel system, the shift interupter, the neutral start switch, the dead man switch, all the wiring for a short and all the connections are tight/clean. When she dies it is like you pulled the coil wire. Also replaced coil and plug wires with my backup set.
Regards,
TxGalz Dah
Regards,
TxGalz Dah
