SO i bought a boat with a 1967 Johnson 20 hp motor the motor runs great but i realized i was only able to go
half throttle out on the lake. so i messed around with it yesterday and i realized when you shift into forward and engage the throttle it stops at about half throttle. then i noticed if you manually turn the prop a little bit then the shift lever goes all the way forward and i can open the throttle all the way. what can be causing this? is this a lower unit problem? i can post pictures with more info tomorrow when i am messing with it
