I have a 1967 Johnson 100 hp golden meteor model v4tl-13a. The pulse pack went out a year ago , so I had a boat shop fix it and they got it running and it now has spark,. so I went to the lake to try it out and at idle and half throttle it ran really rough and the hole motor would shake, but at full throttle it ran great then as the day went on it got worse now it only idles and when u put it under a load it does not go runs rough, the plugs load up, I have checked and all plugs have spark. I have played with the timing but not sure if its set right I don't have any specs on it, have check to see if the carb and distributor are synchronized they are with what the timing is set at right now, it wont even reve up. when I run it in a tank I get oil and gas in the water tank, I have tried different plugs, I cant find a boat shop that well work on it so I guess I have fix it my self . lost don't know what to try any help would be great . thanks I do have a 1968 service manual but things are a little different then my motor.
