1967 Evinrude 40 hp stalls like it is starving for fuel
Spivey
I have a 1967 Evinrude Lark IX 40 Selectric Shift. When I start it and take off it goes a short distance (bout 1/8 mile) and starts stalling. It will die unless I manually pump/squeeze the bulb on the fuel line. Any suggestions as to what might be the problem?
Re: 67 Evinrude 40 horse stalls like it is starving for fuel
Sounds like a failing fuel pump assuming that you do not have any fuel/air leaks between the fuel pump and the fuel supply.
Thanks. I fear a bad pump is the problem but I want to rule out other possibilities before ordering one. It could also be a problem with poor connections in the fuel lines between the pump and the tank. Other than closely examining it (eyeballing it) how can I rule out air entering the lines there?
If air is entering the lines, by the same token fuel will be leaking out which would be obvious via sight and/or smell.
