D
Doc Maynard
Guest
" We had it running on single
" We had it running on single pulls. We washed and wiped it down and I think some moisture got to the coil mounted on the motor. Checked with Tecumseh-obsolete-no parts available. No manual.Coil checks @ 250ohms with voltmeter to plugwire socket & 51ohms thru the coil to the spark plug electrode. Is there a capacitor or condensor in this system that might have blown? It was running fine at idle as we were cleaning it up and died as soon as I sprayed engine cleaner near the coil. Any word on parts availibility or manual would be good to know about. The RJ12YC Champion plug checks @ 48ohms on the volt meter continuity-wise. Best Regards,Doc "
