Hi i'am having a problem getting reverse.The lower unit was rebuilt with new gears, clutch dog and water pump. My freind did the rebuild and when i put the boat in the water with the shifter in reverse the boat went foward almost putting it in the back of the truck.I have droped the lower unit several times trying to line up the shift shaft.I was told to put the shifter in reverse and the lower unit in reverse, with visegrips i turned the shift shaft and can get foward, neutral and reverse. As soon as i install the lower and shift to neutral and back to reverse i lose reverse but still have neutral and foward.Any help, i'am not sure maybe the shaft came out of the cam. I got the boat with no reverse and beleive the owner before had tryed ajusting the cables at the motor could the problem be there?
