"Howdy all. I recently acquir
"Howdy all. I recently acquired this boat and would like to learn a few things about it. I havent been able to find much on the web so I thought I would see if there are any OMC gurus here that might tell me a few things.
First off I have ordered a repair manual. When I went to fill the upper gear case oil leaked from the water intake and from the front of the outdrive just above where the two gear cases meet. I am assuming that this is just a bad seal issue unless someone cautions otherwise. I had attempted to remove the lower unit to see if I could see where the problem lay but on my attempt I could not get the lower unit to drop away any more than a 1/2 inch from the drive unit. I had looked online for a replacement seal kit but I have not seen anyone carry anything earlier than 1970
I would also like to know where to look for a hull number. And if anyone knows what model this boat is.
Other than that oil leak everything in this boat is in fairly good shape. The motor, a 300 cu. in. Cadillac, purrs like a kitten. The upholstery need to be redone as well as the carpet and several other things but it is still a nice boat for a first boat.
Anything else anyone can tell me about this boat would be a great help and much appreciated.
http://gundogforum.com/album/v/Casper/Boat/"
