"Back on Jan 20th yall helped
"Back on Jan 20th yall helped us out with the shift spool issues we had. Thanks again.
I have read through all three of my manuals on shift adjustment and must admit I am feelin like I am standin at the outhouse door, I want to go in but sumpin smells.
The out drive is bolted up and the shifter is in fwd gear. We spun the motor a short burst and the prop shaft turns correctly.
I have read where the distance from the barrel nut to the end of the lower shift cable is to be 6". I have not measured or adjusted that.
Is it so simple that this is the only adjustment? I cant be so lucky. The shift arm is at the fwd lobe. Throttling up, with the motor off of course, the linkage seems to be tight and right. I have not shifted back to neutral since the install.
I have to mention that the shifting slide seemed to be at the maximum throw of the shift shaft arm. Seems to me like I need to back off the cable adjustment (6"?)
The shifter is in the fwd position, the drive is also in fwd gear. Any advise, help or tips before I go moving stuff around would be great.
Regards,
TxGalz Dah"
Regards,
TxGalz Dah"
