KyleWomochil
I have a 1966 Johnson 60 hp super seahorse that runs great at idle or in neutral but when you get it on the lake and put it in gear and floor it it falls on its face and runs like crap. It doesn't have any power and runs like it's starving for fuel or air. I've been through the carb 3 times, new float, seat, needle.. new gaskets.. I've sprayed carb cleaner through every port and orffice in the carb. (Mine dont have the adjustable high speed adjustments they are in side the carb) I've put a new filter on, I've put two sets of new plugs, I've had a mechanic set the timing back in time. I've checked compressing which was 90 on all cylinders. I've checked spark is good. Any advice would be very helpful and appreciated. Thank you!!
