"The motor will run for a shor
"The motor will run for a short time, but gas and oil mix is getting into the points, condensor and magneto housing and kills the spark. Is there a part missing or worn out to stop the fluids from getting up into the top of the motor? I have taken it apart over and over again. I can see a drain hole of some kind at the base where the crank shaft comes through the block, so I assume that the shaft should be lubricated in that area but don't really know. If it is a part missing, what is it called and where can I buy one? Or is it not really salvageable."
