1966 60 hp evinrude
ninjafied
having a problem with this one
just made new wireing harness for the motor when installed on the motor i have continuity over all wires at the junction box plug
plus i have very tiny spark from coil not sure if the wireing may cause that
any ideas
Not sure what your asking?? Any wire that is not broken shows continuity,Thats what that test is for just to make sure the certain wire is unbroken and not shorted.true continuity reads 000 anything other than that there is a break in the wire or a short.A spark at a coil?? Have you used your continuity tester to test the coils??
sorry i'll rephrase
the plug end of the wireing harness once installed has continuity between the different coloured wires when checking from each spade connection but only when installed on the motor.
yes i didi check the coil 0 on the primary side 4000 on the secondary side, only one coil magneto ignition.
