Albertabound
Hello all, I took the boat out for the first time this year (model RXE-14D),I'm having issues. Once on the water I gave it full throttle; having running on one cylinder for about 30 sec. the second one kicked in and away we went. After about half an hour the second one quit for good. Thought it was bad spark but new plugs made no difference. We did figure out its not plugs, nothing was wrong with the other ones(my dad is a mechanic and helped me with most of this problem solving). Compression test showed both cylinders at 110, same as its always been. Pulled it apart because we thought fuel valves were stuck, all leaf valves are in good condition. Looked at pistons and rings to confirm compression which they did. Cranked motor without the carb on to watch the leaf valves and they all work correctly. Figure it might be the top seal on the crankshaft but that doesn't make sense with what we see. The top cylinder is the one that doesn't work. Put it back together and ran it, motor jerks several times a minutes when the second cylinder ignites for one stroke. Took the fuel pump off while running and covered the hole through the intake cover; seems to be alot of hot exhaust back pressure. Now we discovered when we squirt WD-40 direct into the carb sometimes we can get the second cylinder to run for about 20 sec. Now I took a second look at the valves and can see no issues. I know the safety switch does not work but that shouldn't effect things. Besides helping out on our problem can someone tell me what exactly the cut-out switch does? Thanks in advance, Andrew
