B
Bart Dabrowski
Guest
I have a 100hp evinrude that
I have a 100hp evinrude that has not ran in 15yrs.I have since got it running.When you hit the throttle it gets right up on plane but then it starts missing on tell you back of the throttle a bit then it smooths out.The coil was bad i replaced it with a lucas coil.It runs god untell it gets hot then it just quits.You can leave it sit over night and it will start right up.Also the charging system is not working it looks like the bridge rectafire is burnt.
