"I bought a 1960 Lone Star V H
"I bought a 1960 Lone Star V Hull that has a 1965 Johnson Meteor II 90 HP. I replaced the pinion gear on the starter and the engine fired right up. I have had the boat on the water exactly one time. The engine ran great through about five gallons of gas, then suddenly the ammeter showed approx a 10 amp draw. Up to this point the ammeter had shown a good charge, then leveled out slightly above zero. I ran the boat back to shore, loaded it up and took it home. For a time I could charge the battery and the engine would fire up, but the ammeter showed a 7-10 amp draw. With the key on and engine not running the ammeter also showed a 7-10 amp draw. Now if I charge the battery the starter doesn't engage or turn over. Any guidance would be greatly appreciated.
Thank you very much,
James Acre"
James Acre"
