I just aquired a 1965 Evinrude Lark VII 40 hp.
The guy I got it from was, I think, "at the end of his rope with
trying to start this engine. I'm fairly mechanically inclined when it comes to
most engines...and have done automotive engine rebuilds...so I figured I'd take the good deal
and at the very least, gain a nice 14 foot Doral runabout, that I may need to find a motor for.
having done a fairly thorough inspection on both the power head and lower, it seems that there are a lot of new parts, in fact, the lower unit is near mint with new oil, still very good deals, and a brand new impeller. Even all the cover screws have been replaced with new stainless ones. The plugs I've replaced myself, old ones and cylinders/piston heads look pretty clean as well. I removed the carb to inspect and do a kit on it...found a couple of things missing (needle valve spring, low speed idle screw etc) so I replaced the entire carb for an identical one from a recently running parts engine, then I found some wiring issues...there is no wiring 'plugs' so to speak, everything makes sense for the most part (from what I've been able to glean from forum diagrams etc)) except there's questions about how the wires from the safety switch (do both terminals on this switch go to ground?) and the wiring of the cutout switch/two black wires? (How can I determine which terminals on the ignition key switch are the right two to hook up those black wire / cutout switch terminals to using a test light?)
hard to make out those connections in the diagrams, starter seems ok, motor spins and puns water...can smell that it's getting gas...just won't fire up. I suspect it's a coil and points prob or a simple wiring issue. Any suggestions or help would be appreciated.
