Greetings!
Frequent visiter, first post.
Recently purchased this motor for a small 12' fishing boat. Previous owner indicated it wouldn't run at high speed. Unable to run it as he did not have tank and line to test it. Bought it for $75.00. starts first pull every time. Idles fine, mid throttle fine. high speed it misses. Top Cylinder is missing diagnosed from timing light.
My notes:
rebuilt carb. (gaskets, needle, float (adjusted per shop manual),and replaced inlet jet at carb bottom.)
new plugs J4C @.030
new wires, points and condensor's. Points verified by timing light. (cylinder is firing withing the marks on the magneto and flywheel)
brand new tank and hose with inline filter
fuel at 50:1
verified cam plate om magneto is correct per shop manual
verified compression 4 pulls on cold engine @ 80 on both.
By accident, I was applying pressure on the throttle and all of a sudden the thing ran like a beast. timing light showed cylinder firing just fine. As soon as I let the pressure off the throttle, it immediately went back to missing.
Swapped coils and still on 1st (top cylinder) missing at high speed unless I hold light pressure on throttle.
Quite baffled right now
. Hopefully someone else has seen this. So close on this its driving me nuts.
Looking forward to your input!
Mike
My notes:
new plugs J4C @.030
fuel at 50:1
Mike
