1965 evinrude 60 hp no spark
newbie boater
hi i recently bought a 1971 glastron boat with a 1965 evinrude 60 hp motor on it and it turns over but no spark, i read some where the safety switch could be bad it has a automotive starter solenoid on it is there a way to bypass it to see if thats the problem or is there another reason its not getting spark???
The safety switch prevents cranking of the motor ( in gear or throttle open too far )-----------Nothing to do with getting spark.---------------This is equipped with the magneto ignition you will need to clean the 2 sets of points and see if that gets you spark.Replace the condenser.------Maybe the coil needs to be tested as well.
I assume you're checking spark at the spark plug leads.
Check the spark directly at the coil. If you have spark here, replace the rotor.
thank you all for your help and suggestions. i hit it with the ohm meter whan i got home i was gettin power from the coil so there were 2 wires one on each side of the motor white and black, i pulled both off turned key and it purred like a kitten with a full belly. long story short
the black wire was grounding out somewhere. left off runs like it should.
thanks again you all i appreciate the help
