1965 evinrude 18 hp idle problem
doug0218
having problems adjusting the
having problems adjusting the slow speed idle...the motor will idle OK but it will cough or run slightly rough at different intervals...
I've cleaned the carb...should I get a new needle valve? the needle valve has a very slight wear line....barely noticeable.
"The tapered tip of that S/S n
"The tapered tip of that S/S needle valve must be perfect. If worn slightly but not to an extreme, you may be able to clamp it into an electric drill, then at high speed, hold a file to the tip to renew the original taper."
