1965 95hp gearcase explosion
bigge8882
I removed the lower end of thi
I removed the lower end of this motor to clean sand from it and when I had the cover off I shifted the motor out of neutral to forward and gears went everywhere. Does anyone have a diagram of how this gearcase assembly goes together? I paid $20 for the motor and most places I have found want $30 for a manual. Please help
"Hey, I couldnt find an exact
"Hey, I couldnt find an exact diagram for 1965, but if you go to this website, click on johnson/evinrude http://www.usboatsupply.com/Evinrude_Johnson_Parts_Catalog2a.php
Ok then go to the year 1968 9.5 horsepower evinrude/johnson....it will give you a parts diagram, and it should be either identical to your gearcase or close enough to get you back together. The website isnt the best setup, but it works.
Click on my username and E-mail me if you have any problems."
Just shifting the motor when t
Just shifting the motor when the lower unit is off affects nothing. It will all be correct when you reassemble and hook up the shift connecter.
Thanx "K Graham" I got
Thanx "K Graham" I got it put back together this evening with the help of the diagram. Saved me tons of trouble and money thanks again.Do you know where I could find a prop for this motor?
"-There are tons and tons of t
"-There are tons and tons of those motors scrapped at marina's.
-Also you could try a johnson/evinrude dealership with computer program called dealerport, they can look up parts stock in marina's all over the place, and get one shipped to your "
