1965 90hpno wires on the ignition
beersellr
"Good mornin, I have a very ta
"Good mornin, I have a very tall order here.I have no wires at all from the ignition switch to the coil.Where do I start?I am purdy good at fixing things....except elec!Any help would sure be appreciated.Besides, my wife and others doubt I can get this baby running.Thanks a bunch!!!"
What colors are the wires prot
What colors are the wires protruding from the wiring harness that would connect to that switch etc?
Is this the belt drive V-4? If
Is this the belt drive V-4? If so it had 2 types of ignitions- one was a magneto. The entire ignition hung between the cylinders and had one skimpy kill wire going to the key switch. The battery system had a short housing with the points and a presto lite coil. It had a single power wire coming from the key switch. to the coil. and points wire from the coil to the points. Both were very basic.
The magneto had many of the same (but different) components as the slick mag on small airplanes.
Hope you can track down which system you have and wire the key accordingly.
"William.... For reference, th
"William.... For reference, the 1965 90hp model is strictly automotive type ignition."
