1965 9.5 hp model 9322 Fuel Pump Kit
Frostybuds
The parts list for my engine lists my part as #80ish in the parts diagram but the list of available parts for purchase stops at #44 and theres no next page button. Does this mean there are no available parts from the diagram past #44?
I need to rebuild my fuel pump and cannot find the exact kit for my pump anywhere else online. Can I use a later model fuel pump that doesnt bolt in correctly? Like a 73 model?
Is this a Johnson or Evinrude?
If yes, the short answer is that you can use a later model fuel pump that will bolt on CORRECTLY to your block. The newer fuel pumps are physically smaller than the original and - that exact same pump is used on every motor up to a 40 HP.
I have a 1963 9.5 that I upgraded to the newer pump. Also, once you have this newer pump, rebuild kits are readily available.
Just upgrade to the newer pump.
CMOS
