" I have a 1965 40hp johnson m
" I have a 1965 40hp johnson model#RDS-27M.
The engine starts right up, but I have to keep the choke butterfly 95% closed, or it will start to sputter at an idle. the engine seems to run fine on the water except for full throttle,when it will also
sputter ( sort of like it has the hiccups), I have cleaned the fuel fiter and squirted carb cleaner in the carb. and ran it with fuel additive in the gas to clean out the carb and fuel lines. I also put in new spark plugs.This is my first boat that someone gave me for free. I spent $400 to get the lower unit fixed and new waterpump, plus $200 for a new trailer axel. Now I know why it was for free!!
THANKS IN ADVANCE FOR ANY HELP
Also does any one know the correct way to set the low idle needle valve? do I finger tighten it and put the knob back on in the lean position? "
