1964 Johnson 9.5 mq-10 Exhaust housing to impeller spacer
S Carl
I pulled my lower unit apart and the Exhaust housing to impeller spacer fell out when I separated the housings and I can't figure out where it belongs. I would appreciate the help if you could instruct me where it goes and how to get back in place. Thanks
that would mean that the drive shaft would have to go through the middle of spacer? The hole in the end of spacer is too small it wont fit
hope these will do if not let me know
I just bought the damn thing got it home ran it and the lower unit grease had a lot of water in it and a lot of line behind the prop.
Many motors in those days left factory as a short shaft.----It was easy to convert them to long shaft.-----I can not recall ever seeing that part on a 9.5 model.----And I have worked on more than 1 ----Have about 10 of them for parts.
Thanks for the reply's I really apricate it I don't know I will more than likely scrap it I'm not going to put any more money into it.
just got my parts together going to assemble the motor, in the in the prop drive shaft there is a keyway instead of a pin but when i pulled it apart there wasnt a key in it. All of the diagrams I found all have the lining pin. Can i just get a key and kind of fit in there?
