Billysmth555
Hello everyone,
My 9.5hp evinrude was running pretty rough. Figured it needed a carb rebuild. I ordered a kit on the internet. It came in and I took the carb apart. Replaced the float, needle, and valve. Replaced the gaskets it came with also. I reinstalled the carb pumped the gas primer and gave it many cranks. Nothing happened. I pulled the fuel line off and cranked the motor to make sure the pump was working. It did work. Bowl is feeling up but nothing is coming out of the jet. I pulled it apart again and made sure I could run carb cleaner through the jets. None were clogged. I am at a loss and need help. Any suggestions?
