I recently bought a fishing boat with a '64 9.5 hp. It started reasonably easily when running it in a tank. The idle is rough, but I have not gone through the low speed setting steps I've seen on this board.
My main problem is high speed running. The motor runs great at full throttle for 2 or 3 minutes and then slows as if I have backed off the throttle. After a minute or 2 of slow running, it will speed up again, then slow again. Sometimes, applying presure to the primer bulb will cause a speed up, but not always.
Should I just replace/rebuild the entire fuel system or is there a specific area I should pay attention to? I realize this is a bit of a shot in the dark, but any suggestions will be greatly appreciated.
