"I recently purchased a 1963 M
"I recently purchased a 1963 Merc 200 outboard motor.I replaced the coils and ignition parts, cleaned the carb and it runs great.I also replaced the water impeller. When I start and run it there is no water coming out of the motor. If I open the fresh water flush hole water does come out there. Also I changed the gaskets on the exhaust side of the motor thinking there may be something blocking the water outlet. The motor seems to run cool. Should there be a water outlet port or does it exit thru the exhaust."
