I did a compression test not too long ago. I don't remember the results but I know it's good compression. And I don't know about the spark plugs but they are brand new so I'm assuming they're fine. But I'm not positive about the clutch. Is there any test I could do for the clutch?Perhaps it is running on just 1 cylinder.-----So post the actual results of a compression test.-----Does spark jump a gap of at least 1/4" on both leads?----Perhaps the slip clutch in lower unit is binding.
I just took it out on the water and it started to get up to normal rpms when I would turn it fast and put a lot of load on itI did a compression test not too long ago. I don't remember the results but I know it's good compression. And I don't know about the spark plugs but they are brand new so I'm assuming they're fine. But I'm not positive about the clutch. Is there any test I could do for the clutch?
I also just ran it out of the water and it got to full rpms in forward when it wasn't pushing the boat. But as soon as I put it back in the water it didn't want to get to full throttleI just took it out on the water and it started to get up to normal rpms when I would turn it fast and put a lot of load on it
No I only ran it for a couple seconds trimmed up then put it back in the water.Did you just ruin the water pump by running it dry.----Also was a meaningless test !
