1962 johnson electric shift
dougsamual
No forward drive I've take
No forward drive I've taken apart the lower end and found that the front coil was junk.I ordered a new one and installed it but it doesn't read on the OHM meter.Anyone that can help me with the electric shift?
What do you mean doesn't r
What do you mean doesn't read on the OHM meter? Do you have proper voltage to the coil? Do you not get a resistance reading across the coil? Was it a used coil or a new one?
"Contact the seller and tell t
"Contact the seller and tell them, see if they will send you a replacement for the defective one."
