Corey Shumaker
Bought a 1962 Starcraft from a neighbor with the electric shift 40HP Johnson. She said it had reverse only. I may have found a bad connector under the panel but with further checking with power to the blue and green wire connectors at engine, both spark as if the coils are good but with power to either one the prop doesn't lock up but becomes harder to turn in both directions. I can turn it fully around continually but it will not lock up. Then with power to one of the leads and the starter running and engine turning over (not starting) , the prop does not turn at all. I drained the oil hoping it was really sludgy but it didn't look too bad.
Any help would be appreciated.
Also, can this lower unit be disassembled and reassembled without special tools?
